Convertion from fork to springer, 2000 1200xl
Old 01-02-2014 | 04:01 PM
ClodeV's Avatar
ClodeV
Default Convertion from fork to springer, 2000 1200xl
I was hoping that i could get some feedback from those of you that have converted a sporty from stock forks to a springer front end. I have a 2000 XL1200 that i love but just want a longer front end and thought converting it to a springer front end with a +4 or +6 would be the way to go. Here are my concerns.
1: Would a DNA +6 spring front end include the rake to push the wheel forward?
2: What handling issues crop up with extending the front end and adding a springer system
3: i believe i will need a new front brake caliper for the springer or will the stock work?
In advance Thank you
Old 01-02-2014 | 07:13 PM
TonyGinFla's Avatar
TonyGinFla
Before making a conversion like this, do a little research on the effects it has on "rake and trail" . As a starter, http://auto.howstuffworks.com/choppers2.htm
Understanding rake and trail will help you make a better decision. You will have to modify the front brake to use a springer. There may be adapters that will let you use a Harley caliper. Look at close up pics of a few and you'll see how they are configured.
Old 01-02-2014 | 07:50 PM
chappy99's Avatar
chappy99
Old 01-02-2014 | 09:42 PM
bikerlaw's Avatar
bikerlaw
Answer: No. DNA Springers are zero degree rake. The wheel would physically be farther forward because of the springer rockers as well as the fact the forks are longer than stock. But not because of any added rake.
Awful handling. Your whole motorcycle would be tilted towards the rear with a 6 over springer. Not only would it look ridiculous, it would be very top heavy and loose feeling. A 4 over would be right at he most I would ever put on a stock rake bike. Stock length or 2 over would be perfect. Also, Springers, especially the bottom of the barrel DNA Springers bounce and rattle. I have run two DNA's in the past three years. One on my Shovel and one on my Dyna. They are very poor quality to say the least.
There are a couple company's that make a bracket to mount the stock caliper on a DNA springer.
Lastly, you need to know that the basic out of the box DNA Springers WILL NOT bolt to a Sportster without a lot of modification. You can get a DNA "type" springer that's been set up to bolt right on.
I believe this one requires a lot of modification as mentioned in their video:
http://www.ebay.com/itm/New-2-Under-...e3abdd&vxp=mtr
I think these two are bolt ons:
http://www.sportsterspecialty.com/cu...ront-ends.html
http://www.paughco.com/2008-catalog/...-springers.pdf
Most springers are set up for big twin necks. Make real sure your buying one that will fit a Sportster neck. Or be prepared for a lot of extra work. There is one other company but I just couldn't remember it off the top of me head. Either way, spend A LOT of time researching and call your seller. Make sure you get the right one, not a basic DNA.
Old 01-03-2014 | 12:02 AM
ClodeV's Avatar
ClodeV
This was some great info to consider. Thank you on your feedback it gave me alot to think about i just might leave Elly alone and get an older bike to play with.
Old 01-06-2014 | 06:49 PM
Rob Robb's Avatar
Rob Robb
Default Bikerlaw, which springer would you recomend?
So you've had 2 DNA's & don't like them. With your experience what company would you buy from in future? 30 yrs ago I had a 59 FLH PanHead in a 47 stretched & raked rigid frame w/6" over modified stock Harley springer. It would pogo at high speeds if you hit a bump & was difficult turning at parking lot speeds but other than that I loved the way it handled. It probably would've been better if it had the shock, which it didn't. I'm considering a Paugacho wide springer 2" over w/shock for my 2013 Sportster 72 when I get rich. Have you are anyone you know used Paugacho?
edjack
04-03-2014 12:51 AM
reedc89
05-05-2011 01:18 PM
donovann2o
04-20-2011 01:54 PM
Rodney Wise
03-24-2011 06:15 PM
jtbredneck351
04-07-2009 05:45 PM
