What did you do to Your Sportster Today?
#9571
#9572
The threads inside the cap are metric which means they are very fine, unlike standard or SAE threads and are easy to strip if you start them in wrong. They are easy to get out but watch out for them flying through the air as the coil spring inside is released. Before inserting the caps after you change the fork oil, place the cap inside the fork to see how deep it has to go before it actually engages the thread. If memory serves me, it is about 1/4" deep. I believe this is to force you to have the threads exactly vertical so they start correctly and don't cross-thread.
I had such a hard time getting mine back in that I replaced them with these so that I can replace the fluid without having to remove the springs:
https://www.jpcycles.com/product/230...tube-top-plugs
Hope this helps.
Hope this helps.
WKNDS (09-18-2019)
#9573
#9574
drain screw at the bottom of slider....
http://partsfinder.onlinemicrofiche....ORK%20ASSEMBLY
The older 2013-. Notice #8 the drain screw & washer...
hth,
T.
#9575
As far as replacing the fork oil in the newer forks that don't have the drain screw, I would think that you could insert a tube and suction the old fluid out. Be sure to measure how much came out and replace the same. Mine was about 10 oz. per fork. The fluid is light and thin, so it should be an easy job.
If anyone is interested, I can post the steps I took. I always right down the tools, parts and steps after doing a job to make the job easier the next time I do it. It's sort of like the old carpenter's rule: Measure twice, cut once.
#9576
Ok after years of tellin ppl to get longer damper rods..here is my poor man's suspension mod that I'm doing on my sporty (yea cos parts are expensive n hard to come by where I live. This cost me $3 bucks) so u gotta do what u gotta do.
Any input from suspension experts about these softer top out springs becoming an issue in the long run is appreciated. (Also i am aware of the added unsprung weight, so no debate needed) thanks. Wonder if the extra oil will be an issue as well..hmm
Btw while I'm at the machine shop making the Aluminum spacers, i machined some stainless steel breather bolts as well ($2)
#9578
Agree with you on the breather's when they drool..I'm going for a new air cleaner, not finalised on one yet..but thought, might as well have these on hand now than later.
Here is what my stock ham can mod looked like
#9579
HotRod917 (09-22-2019)
