What did you do to Your Sportster Today?
#8011
#8012
That's about what I would see riding around 50-60 mph, temps in the 200* range. Crank it up to 70 mph or so and things start to heat up fast. Last weekend my son and I went out for a few hours and it was HOT, on the ride home I was seeing REAL close to 250*.
I was going to hold off and do the cooler this winter, but after that, and seeing the forecast is for heat and alot of it this summer, I decided to do it now.
Wizzing Along 🍺
#8013
I've installed a pair of Rush slipons, and a SE Stage 1 air cleaner on the bike, I reflashed the ECM with a FP3 using V&H MAP for their twin slash slipons, and a high flow air cleaner. I was told the twin slash and the Rush slipons were comparable as far the MAP was concerned. The bike runs great, plugs look good, and I took a head temperature reading using the FP3, the head temp was in the 380* range at highway speeds. I asked about that temp on here and was told it is 'normal'. That was my first concern with the high oil temps was that the bike was running lean, but nothing points to that. That is when I decided to go with the oil cooler.
#8014
#8015
#8016
#8017
#8018
#8019
What kinda seat you got there if ya don’t mind me asking ?
Wiz 🍺
