What did you do to Your Sportster Today?
#8002
The cooler and frame mounts arrived this afternoon, got everything mounted up, and took the bike out for a test run for 20 miles or so. So far no sign of any leaks AND where I was seeing oil temps in the 230-240* range at 70 mph, I am now seeing 210-220*F. Good oil temps especially seeing it is in the low 90's here with oppressive humidity.
#8004
I was going to go with the HD cooler with the Jaggs adapter since it has a thermostat, and it is cheaper than the Jaggs but, the HD cooler does appear to be wider than the Jaggs. That is why I went with the Jaggs cooler to keep it as compact as possible
I wanted to mount it higher but, I have relocated the turn signals down to the lower fork clamp on the triple tree. I had to go lower to allow clearance between the cooler and the signal housing when the bars are turned all the way left.
#8005
Started installing the oil cooler and adapter.
The adapter arrived a few days ago, it is cast aluminum and it looked to either have a black oxide or almost looks like a parkerized finish. I found this paint I had and painted it so it would closer match the engine cases.
I removed the oil filter and found the filter nipple was loose and tightened it down. Something I guess everyone should be checking regularly.
I installed the oil filter adapter using the new adapter nipple. Only thing I wasn't too happy about was, it is made from aluminum. Steel would have been a better choice IMO as aluminum and steel expand and contract differently and it could cause it to loosen up although I did put a couple of drops of blue loctite on the threads. Time will tell... I used a small piece of wood cut into a wedge to stop the adapter from rotating when tightening it up.
Finished the adapter install, wrapped the lines in a plastic bag and waiting for the cooler and frame mounts to get here. USPS has them out for delivery today, should be here any time.
Wiz
#8006
Yesterday after installing the cooler and in mid 90* temps after 25-30 miles at 70 mph I was seeing 215-220* oil temps. My son and I are headed back out shortly and be out most of the day. It's going to be in the low/mid 90's again so I'll be keeping an eye on the temps to see if they remain lower on longer rides.
#8008
I would normally see 220-230* unless I was running 70 mph or more, then the temps would hit 240*ish. Last Sunday my son and I were out and riding home in 95* temps at 65-70 mph and I was just under 250*. This is at the tank using the HD analog gauge.
Highest ive seen is 220 at the tank with the same oil dipstick / analog temp gauge, that was riding 2 up @60mph on a 80’ day so I’m guessing we’re pretty close.
Love that synthetic, just for that little extra peace of mind.
Thx buddy 🍺
Wiz
#8009
https://mobiloil.com/en/faq/product-...View=20&Page=1
#8010
Agree on the synthetic...per Mobil 1 conventional oil starts to break down at 250F while they claim V-Twin 20W50 can take 300+ degrees without damage.
And from what I’ve just read, the Dino oils just getting ready to sheer.
Wiz 🍺
