What did you do to Your Sportster Today?
#7921
The following 4 users liked this post by DBrevit:
#7923
Mud flap?
Just wondering.
#7924
Dropped off the fender with the powder coating guy. he scraped off the old paint in one place and nothing but rust under it. No primer, no old paint... nada.
It's going to be soda blasted and coated properly... gloss black. Will have it back friday in time for a weekend run or two.
#7926
Finally got the 12" bars installed. After being quoted over $700 to throw these ($75 bars) on with extended cables and all there was no way I wasn't going to do this myself.
Took a bit of trial and error to finally get the new extended clutch and throttle/idle cables adjusted perfectly but thanks to the help of fellow forum members and that Harley bible (owners manual), everything seems to be on there pretty perfectly.
These bars are phenomenal. Ride is much more comfortable and my shoulders sit much more naturally with these.
#7928
Those bars look great. I'm about to start the process of doing an extended wiring kit in the next day or so. Any tips?
#7929
When your screwing the clutch cable into the primary case, take your time and be patient, could be tedious, helps if you have someone holding the other end up while you're turning, if it doesn't screw in easy, don't force it.
Make sure to make all your cable adjustment as stated in the manual, to the smallest detail. That's probably where I ran into the most frustration, took me a good amount of time to get it adjusted perfectly.
There are tons of videos out there to help you with the swaps, ill ink some of the most helpful to me below.
Good luck!
#7930
The following 3 users liked this post by DBrevit:
