What did you do to Your Sportster Today?
Old 05-31-2018, 10:38 AM
Wizardofaus's Avatar
Wizardofaus
Wizardofaus is offline
Originally Posted by awilson40
I ordered new SE slipons....but alas, they are on back order
Yeah what’s with that , Every time I want something from the local dealer they either have to order it and then have to wait 2 weeks cos it’s on back order.
Nothings in stock anymore
Wiz 😒
  #7882
Old 06-01-2018, 02:06 PM
underwhelmd's Avatar
underwhelmd
underwhelmd is offline
I installed Biltwell Kung Fu grips. Completely different world than the slippery thin stock grips.
The left side came off easy. One slit with a knife and the stock grip was off. Installed new grip with hair spray. Let sit overnight. It's not moving. Ever.
Throttle side was a problem. Old grip was glued on with something that made it bond with the throttle tube. I called my local dealer and was told I can't buy that throttle tube from them without a grip on it already. What? OK, I says, Biltwell sells one. Yeah, he says, I can sell you that one for 70$ plus tax and a long wait. No thanks.
I removed the throttle tube and spent a couple hours with a sharp knife skinning off the old grip, piece by piece. The new grip was too tight on that tube to use hairspray.... it setup too soon and couldn't get the grip all the way on. I used wd40 and it went on fine. Let sit overnight.... it's not going to move....too tight on there. Tested on the highway. Done. I like them.
  #7883
Old 06-01-2018, 02:50 PM
JPoff219's Avatar
JPoff219
JPoff219 is offline
Stage I
Red Lewy are you using 1" risers? Been back and forth about getting some risers for when I install drag bars.
  #7884
Old 06-01-2018, 03:08 PM
Ben221's Avatar
Ben221
Ben221 is offline
Thought about all the steps involved to reseal the cases. What a pain the *** for some damn clear sealant. Might as well check and hone the bores and new rings based on spec, maybe new pistons.
  #7885
Old 06-01-2018, 03:15 PM
181fsc's Avatar
181fsc
181fsc is offline
New Le Pera seat.
Love how low you sit
Stripped the paint off my sissy bar.
  #7886
Old 06-01-2018, 06:38 PM
Old Iron Man's Avatar
Old Iron Man
Old Iron Man is offline
Originally Posted by Wizardofaus
Nice ride man .... What does dealer storage set you back ? And do they do it on a month to month deal ?
thx.
Wiz 🍺
Here he comes. The grim reaper.
And there she goes for winter hibernation.
They charge $300. They come to pick it up in the fall, and bring it back in the spring. Although most guys want to run over there and pick their bike up as soon as the first nice day comes. They also do an oil change and whatever other winter stuff they do, including trickle charging the battery. If you have $1,500 of work done in parts & labor over the winter, they credit you back the $300. Not a bad deal.
  #7887
Old 06-02-2018, 12:19 PM
RRider's Avatar
RRider
RRider is offline
The roadster got Hammered today , well the air filter anyway.😊
The service from Hammerwas fast, all arrived packed well ,was easy to mount and gives improved leg room.
I like it!
  #7888
Old 06-02-2018, 12:27 PM
MoneyFor's Avatar
MoneyFor
MoneyFor is offline
I bought a 4,5 x 16 rim, rvs spokes and hub, combined the lot to a wheel and put a 170/70 Shinko ww on it.
Mounted in the 48
The Shinko is about 175 on the rim and the stock 150 was only 140 on the rim.
  #7889
Old 06-02-2018, 12:31 PM
rhino1250's Avatar
rhino1250
rhino1250 is offline
Received 1,346 Likes on 616 Posts
Ordered new exhuast and solo tail
  #7890
Old 06-02-2018, 01:10 PM
stratcpo's Avatar
stratcpo
stratcpo is offline
Ordered new Mustang tripper seat with backrest. The stock seat was only ok for about 30 miles before I had to take a break. ENJOY!!!
Quick Reply: What did you do to Your Sportster Today?
