What did you do to Your Sportster Today?
Old 02-27-2018 | 07:59 PM
cvaria's Avatar
cvaria
Originally Posted by johnny_bravo00
Lol got up to 12 here in Toronto today. Went out for a good 2 hours, bobbing around the city. Most people were jacket-less. So nice in the sun. First good ride of the season!
lol, i remember being in north dakota for three months. first day i was there, it was -55 degrees, that went on for a few weeks the it jumped to 25-30 degrees.... felt like it was 90 lol. we were out in shorts and t shirts.
  #7362
Old 02-28-2018 | 10:46 AM
craigthecarpenter's Avatar
craigthecarpenter
After making the outside of the forks like new it was time to turn my attention to the inside. So, I changed the seals, bushings, seals and oil.
Everything that holds back a flood of oil or brake fluid on this bike will be replaced by the time I am done.
Oil lines on the motor are turning out to be more of a PITA than expected. Getting at the feed lines on the oil pump isn't easy with out removing the cam cover or the actual pump. Not impossible, just hard.
Craig
  #7363
Old 02-28-2018 | 11:13 AM
deadrubberboy's Avatar
deadrubberboy
Rode it to work. Had an exciting thing happen...
I heard an unusual sound. I looked down to see my shift pedal spinning in the wind like a pinwheel. I put my foot under it to keep it from turning (slight pressure, not enough to actually shift) and the dang thing came off. It was balancing on the toe of my boot. Thankfully, I was able to easily reach down and grab it while pulling off the side of the road. Even still had the bolt through it.
I was able to put it back on and be on my way in under 2 mins. Going to red lock tight it at lunch.
  #7364
Old 02-28-2018 | 11:19 AM
cvaria's Avatar
cvaria
glad you caught it
deadrubberboy (02-28-2018)
  #7365
Old 02-28-2018 | 12:12 PM
johnny_bravo00's Avatar
johnny_bravo00
Crazy!
  #7366
Old 02-28-2018 | 12:30 PM
Bluesrider.df's Avatar
Bluesrider.df
I'm really disappointed you pulled over. A real biker would've squirted some Loctite on and reattached it without even backing off the throttle.
LOL, seriously that is epic, just another day riding the bike.
  #7367
Old 02-28-2018 | 12:36 PM
johnny_bravo00
Damn Motogadget grip on the throttle side is loose. The round piece that the grip threads on to has a bunch of set screws around it holding it on to the actual plastic throttle. A very hard piece to get right, either its too loose and will spin or its too tight or tightened unevenly on the plastic throttle making it so it wont spin right.
Im guessing some of the set screws either backed out a bit or the plastic is worn underneath. The kicker is that the motogadget bar end indicator stops me from being able to just reverse the grip off and readjust. Hopefully I have enough slack in the wires to pull them off just enough to tighten up. The indicators are connected under the seat and pulled through the bars. sigh*
Attached Thumbnails What did you do to Your Sportster Today?-motogadgetm_grip_billet_aluminum_grips_black_750x750.jpg
  #7368
Old 02-28-2018 | 12:57 PM
ApexRider's Avatar
ApexRider
One time I lost my shift lever at night on a busy freeway doing about 70 MPH. Pulled over on the left shoulder and walked about a quarter mile using passing car's headlights to scan the road and found it in the middle of the lane. Held it in place with my foot till I got home 30 minutes later.
And then I found twenty dollars.
  #7369
Old 02-28-2018 | 02:28 PM
deadrubberboy
Originally Posted by cvaria
glad you caught it
Thanks! Me too. I can't believe I didn't lose it to traffic etc. If I hadn't noticed til I needed to shift and it was gone it could have been BAD.
  #7370
Old 02-28-2018 | 02:29 PM
deadrubberboy
Yikes. As I was putting it back on I was wondering what I would have done if it was GONE. Best I thought of (besides calling co-worker to come get me) was boot lace to pull up on to shift the rest of the way. Or just put it in 2nd and stick to back roads.
