What did you do to Your Sportster Today?
Old 01-08-2018, 04:55 PM
WKNDS's Avatar
WKNDS
WKNDS is offline
Received 1,360 Likes on 986 Posts
Originally Posted by lewk
Got any pic or sketch of what you have in mind? I'm curious as to what you'll create... I too haven't really found one I like. But in my case it's primarily because I find the filters wayyyy too big and I am trying to avoid running a hose line down to the ground.
Nah, still futzing around with it. It's all AN fittings & braided lines,
down to a catch-can then vented "down to the ground"
thanks,
T.
  #7122
Old 01-08-2018, 08:49 PM
Grey_Beard's Avatar
Grey_Beard
Grey_Beard is offline
Got around to installing the items I got for Christmas. DK Customs 425 Outlaw ac with premium discrete breather system. I already had their catch can so I decided to try this first instead of the filter, and I added an in-line ET Performance crank case breather valve as a backup to the umbrella valves. And also installed the analog tach /digital combo and fuel sender unit. All went in without a hitch.
Attached Thumbnails What did you do to Your Sportster Today?-20180108_210259.jpg   What did you do to Your Sportster Today?-20180108_210215.jpg
DK Custom (01-13-2018)
  #7123
Old 01-08-2018, 09:04 PM
Sam_48's Avatar
Sam_48
Sam_48 is offline
That gauge looks awesome Grey_Beard! I am anxious to receive mine from Surdyke.
Grey_Beard (01-08-2018)
  #7124
Old 01-08-2018, 09:20 PM
Grey_Beard's Avatar
Grey_Beard
Thanks Sam 48! Just remember to have the fuel sender, the jumper (replaces the low fuel resistor which is included) and the gauge installed before re-installing the main fuse and switching on the key. Both fuel sender and speedo will sync with no problems.
  #7125
firehawk6's Avatar
firehawk6
firehawk6 is offline
Received 8,571 Likes on 3,284 Posts
I've been eyeballing that speedo/tach combo at Surdyke myself. Just haven't pulled the trigger on it yet.
Is it as simple as unplugging the connector from the back of the factory speedo, and plugging in the new one other than the settings?
Inquiring minds need to know...
  #7126
Old 01-08-2018, 09:27 PM
Grey_Beard's Avatar
Grey_Beard
Yes it's that easy provided you don't want the fuel gauge. If you do want the fuel gauge then the tank needs to be removed. Still a very easy process. I removed my tank last weekend only because I was looking for something to do which took about 45 minutes (only because I'm **** with the way I do things). Tonight was about an hour total for the complete installation.
firehawk6 (01-08-2018)
  #7127
Old 01-09-2018, 11:38 AM
cchuck3537's Avatar
cchuck3537
cchuck3537 is offline
That looks awesome!
  #7128
Old 01-10-2018, 06:15 PM
DBrevit's Avatar
DBrevit
DBrevit is offline
Did the decal on right tank today, will do the stripe work next week, also finished the headlight wiring along with horn and trip button on side of headlight, foot rests on, wet sanded right tank and compound once (more to do)
Attached Thumbnails What did you do to Your Sportster Today?-img_2890.jpg   What did you do to Your Sportster Today?-img_2891.jpg   What did you do to Your Sportster Today?-img_2892.jpg   What did you do to Your Sportster Today?-img_2895.jpg
The following 3 users liked this post by DBrevit:
cvaria (01-10-2018), deadrubberboy (01-11-2018), Grey_Beard (01-10-2018)
  #7129
Old 01-10-2018, 07:10 PM
Dudepants's Avatar
Dudepants
Dudepants is offline
Wow, looks awesome! Excellent work
DBrevit (01-11-2018)
  #7130
Old 01-11-2018, 09:36 AM
deadrubberboy's Avatar
deadrubberboy
deadrubberboy is offline
Legit. Tight work Sir.
Quick Reply: What did you do to Your Sportster Today?
