What did you do to Your Sportster Today?
Old 11-17-2017, 05:26 AM
WKNDS's Avatar
WKNDS
WKNDS is offline
Received 1,366 Likes on 989 Posts
Originally Posted by cvaria
...snip.... I even canceled the dyno with doc.
...snip...
Thats unfortunate, I think you would be impressed with the results.
T.
  #6812
Old 11-17-2017, 08:16 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,201 Likes on 1,687 Posts
T.
you are right. Id just rather put that 2k in tangible mods. The minute i change something, all that cash is out the window and i have to go back and have it retuned. I may still do it later on if i come off the grenades. I just cant part with them....
i think he could probably get 125/125 out of the dyna and smooth out the 1-4k range. I don't think i will be messing with that bike much. It's just missing something. .. not sure what "it" is. Whatever "it" is in the sportster though.
  #6813
Old 11-17-2017, 09:21 AM
ApexRider's Avatar
ApexRider
ApexRider is offline
I understand this perfectly.
So I've noticed others have had issue with their exhaust flange nuts loosening, especially after putting new pipes on, and I've noticed the same thing on mine as well. Torque spec is 120 in-lb (10 ft-lb), and so far I'm 2 for 2 in riding, then checking and tightening back to spec. Is this normal for a period until the pipe-to-gasket purchase is fully seated, or should I look into somehow locking the bolts on and/or frequently checking them as they will forever be a pain in the ****? The lower-rear bolt just became a bear to access with the Cobra heat shield in place, so I'm inclined to at lease pull the shields, torque it down, and put a wrap of stainless safety wire on the threads to prevent it from backing out. What's your experience with your nuts?
  #6814
Old 11-17-2017, 09:50 AM
johnny_bravo00's Avatar
johnny_bravo00
johnny_bravo00 is offline
So I've noticed others have had issue with their exhaust flange bolts loosening, especially after putting new pipes on, and I've noticed the same thing on mine as well. Torque spec is 120 in-lb (10 ft-lb), and so far I'm 2 for 2 in riding, then checking and tightening back to spec. Is this normal for a period until the pipe-to-gasket purchase is fully seated, or should I look into somehow locking the bolts on and/or frequently checking them as they will forever be a pain in the ****? The lower-rear bolt just became a bear to access with the Cobra heat shield in place, so I'm inclined to at lease pull the shields, torque it down, and put a wrap of stainless safety wire on the threads to prevent it from backing out. What's your experience with your nuts?
I was thinking about the same thing as I just found the same thing on mine.
I wonder if theres room to add a second nut to act as a lock. Or possibly just add lock washer.
  #6815
Old 11-17-2017, 09:59 AM
cvaria's Avatar
cvaria
cvaria is offline
probably could have worded that differently
I've had them go missing and the pipe dislodge.
check them routinely. Some folks double them.
Jegs sells 12 point 5/16-24 nuts made by ARP that will not budge. http://www.jegs.com/i/JEGS-Performan...84102/10002/-1
The following 2 users liked this post by cvaria:
ApexRider (11-17-2017), johnny_bravo00 (11-21-2017)
  #6816
Old 11-17-2017, 11:23 AM
ApexRider's Avatar
ApexRider
looks like Belleville Spring Lock Washers might be a good option as well, and can be had in stainless.
maybe a dab of red loctite at the edge of the properly torqued nut? Sure, it's going to get roasted from the heat, but the material itself may be enough to prevent loosening and unneeded drama in the middle of a trip. Just throwing that out there.
  #6817
Old 11-17-2017, 11:28 AM
cvaria's Avatar
cvaria
cvaria is offline
NO LOCTITE!
blue becomes lube and red is a future headache
  #6818
Old 11-17-2017, 11:43 AM
ApexRider's Avatar
ApexRider
yeahbut... which is the worser headache, nuts falling off in the middle of a road trip, or having to torch and wrench off next time the pipes need to come off?
  #6819
Old 11-17-2017, 11:48 AM
cvaria's Avatar
cvaria
cvaria is offline
it really doesnt happen like that. I'd just add checking the nuts to your TCLOCS list. (Already there but, make a special effort)
https://www.google.com/url?sa=t&sour...Wnd2dh1xDCSejm
  #6820
Old 11-17-2017, 12:00 PM
ApexRider's Avatar
ApexRider
Quick Reply: What did you do to Your Sportster Today?
