What did you do to Your Sportster Today?
Old 05-04-2020, 09:43 AM
DK Custom's Avatar
DK Custom
DK Custom is offline
Platinum Sponsor
Received 4,212 Likes on 2,448 Posts
Originally Posted by Packgrog
At last! I FINALLY installed by new intake and external breather from @DK Custom on Saturday. Went out for a joyous test ride afterward, then went out again on Sunday to pick up those air shocks. Both rides were excellent, and I’m definitely happier with the lower profile intake. It’s a good thing that I got a proper cover for the intake, though, as we had some unexpected rain on Saturday night, and I’d left the girl uncovered. No water logging with this cover! Most excellent!
Also took off the stupid chrome cover for the rear master cylinder. Should allow a little more cooling of the exhaust.
Looking good! Glad to hear you're enjoying, and we appreciate the business.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
Call/Text: 662-252-8828
Packgrog (05-04-2020)
  #10972
Old 05-04-2020, 09:49 AM
Ben221's Avatar
Ben221
Ben221 is offline
Installed a chrome coil cover, removed the sissy bar, luggage rack, installed lay down plate and brake light, went with a solo seat and replaced the leaking oil drain line.
  #10973
Old 05-04-2020, 06:33 PM
MikeBel's Avatar
MikeBel
MikeBel is offline
Received 1,564 Likes on 671 Posts
Default Red Alert!
Another member (Baldy54,I believe) recently posted a photo of his Sporty with red calipers. I was hooked; I thought they looked fantastic. I didn't want to paint my original calipers so I went on Ebay and luckily found a set of calipers for the 1200S.
While I was at it, I decided to paint the DK chin fairing the same color. Originally the chin fairing was black and it was almost invisible. And then I decided to paint the HD logo on the front axle nut covers. (Yes, this is a sickness.)
It may not be for everybody, but I love how it all came together.
The following 3 users liked this post by MikeBel:
Andy from Sandy (05-05-2020), Iron Horse 13 (05-04-2020), Packgrog (05-05-2020)
  #10974
Old 05-04-2020, 06:36 PM
Iron Horse 13's Avatar
Iron Horse 13
Iron Horse 13 is offline
looks good.detail is where its at.
The following 2 users liked this post by Iron Horse 13:
MikeBel (05-04-2020), OCSpringer (05-04-2020)
  #10975
Old 05-04-2020, 06:41 PM
Tileman2692's Avatar
Tileman2692
Tileman2692 is offline
Took trip to Ormond Beach Fl. From Cape Coral, round trip 309 Mls. Stayed there two days then home.
oh yea did some surf fishing too. Oh yea I'm the short one in the middle
  #10976
Old 05-04-2020, 06:48 PM
Tileman2692
I've been looking for a pair of bags like that where did you get them.
Ive been looking for a pair of bags like that where did you get them
  #10977
Old 05-04-2020, 10:46 PM
handirifle's Avatar
handirifle
handirifle is offline
Received 1,709 Likes on 1,141 Posts
Maybe I am paranoid, but I would not want that little oil filter right next to my rear brake rotor. If any oil does come out of it, it could get on that rotor. But at least the rotor won't get all rusty that way.
When I did mine, I ran the line to a little inline fuel filter, and laid the filter on top of the crankcase, at the back of the engine. It was all painted black so you have to look for it to see it. The exit line went down along side the brake reservoir line. If any oil dripped (never saw a drop on my garage floor for the year I had it) it would hit the ground about 3" to the side of rear tire.
  #10978
Old 05-05-2020, 09:42 AM
Packgrog's Avatar
Packgrog
Packgrog is offline
Yeah, I'm not loving the placement. I tried to shift it back a little to get it further from the rotor. May try shortening it further. I don't use the rear brake a LOT (mostly just when going downhill so that I don't risk flipping if I accidentally get too grabby with the front brake), but it would indeed be better to keep that clean.
One thing not evident from the angle of that shot is that I tried to secure it so that the little filter was tucked up more under the bag so that it would be less likely to sag down and touch the rotor. One problem is that it's tough to shift it much further forward toward the passenger peg while still having enough length in the zip tie to keep it secured. I suppose I could just hang it from the p-peg mount itself and be done with it. Not likely to ride with a passenger in the foreseeable future anyway, and that bag already gets in the way of that peg...
  #10979
Old 05-05-2020, 09:51 AM
Ben221's Avatar
Ben221
Ben221 is offline
They came with the bike. I have seen them for sale occasionally on ebay or facebook market place pretty cheap. Good luck
  #10980
Old 05-05-2020, 10:25 AM
OCSpringer's Avatar
OCSpringer
OCSpringer is offline
You will have less of an issue if you actually remove the filter and just run an open line. The vapor from the breather will saturate the filter element and it will actually start blowing oil all over the place. It will also start restricting flow quite a bit. Once the filter is clogged when you are really getting on the throttle it is like the filter is under pressure and it sprays oil mist everywhere. I had that exact setup on my '03 and it ended up being a mess. A catch can is the only clean solution. This is how I ended up routing mine. When the pipe is on it is really not that noticeable. I drain it once every couple weeks via a drain plug on the bottom.
The following 2 users liked this post by OCSpringer:
Iron Horse 13 (05-06-2020), Packgrog (05-05-2020)
Quick Reply: What did you do to Your Sportster Today?
