Will 1200 jugs and pistons be a direct swap to a 883 same year ?
Will 1200 jugs and pistons be a direct swap to a 883 ?
Will 2003 1200 jugs and pistons be a direct swap to the lower half of a 2002 883 ?
I can get a near perfect matching set jugs and pistons.
Will the 1200 pistons fit on the 883 rods. other word's a cheaper swap, using All Harley parts.
I can have all the parts needed to make the swap for $200.
Bob
Bob
Since the heads of the 883 and 1200 are different, it's not technically a direct swap. I believe you'd need reverse dome pistons. I could be wrong.
I would think it would either have to do with the compression ratio or valve clearance. If I'm wrong someone will correct me. lol
I think Hammer or NRHS carry pistons for that conversion, or they probably know what is best to use if going that route. One, or both, offer a 1212 kit, which I believe is a bore job on your existing cylinders, assuming they are the earlier thick wall type. I think the later 883 jugs have thinner bore liners.
John
John
John
John
Since the compression would be a little high, using 883 heads.
Is there enough material, dome thickness to machine a relief in the 1200 piston top?
Should be ok as there is valve pocket, will machine no farther then its depth.
Maching is not a problem, as I am a machinist
