Need Some Help on Socket Size
I have been trying to remove the Negative cable which is bolted to the Crankcase on my 2012 Sportster 48. Does anyone know what size and type socket will work. I think a flex socket 1/4" or 3/8" drive is needed but I am not sure which drive or socket size. I would like to buy one so I can remove the Battery. I was not able to get it with a universal and a separate socket so I would like to buy the correct one.
thanks, Barrier
thanks, Barrier
Thanks for the reply Sporty Pig.
I tried a 1/4" drive extension, universal and a socket I was not able to get a clear engagement on the nut the socket and extension were too long. I figured a flex socket in 1/4" drive would work. Before I buy one I would like to know if that would work and what the correct socket size is. I cannot easily get to the bike so I need to know before I continue to search. Flex or Swivel sockets in 1/4" do not seem to be easy to find. I would hate to search and buy and find that it does not work.
Thanks, Lew Barrier
Thanks, Lew Barrier
Thanks for the response lo-rider. I have many dial indicators the location is very difficult to get to due to the location on the newer model Sportster and the need to remove the Battery for Winter storage my inquiry would save some time. My purpose was not only size but need to find what others have used to access the nut. When using a 1/4 socket and a universal the extra length of the two would not enable me to engage the nut. I just figured that others have taken the battery out and would have the info readily available.
Barrier
Barrier
