Kit To Modify Keihin Carb
Anybody seen this on ebay before? waste of money or no?
http://cgi.ebay.com/ebaymotors/Perfo...QQcmdZViewItem
RE: Kit To Modify Keihin Carb
Most kits I heard people talk about consisted of (1) bigger slow jet, (1) bigger main jet and (4) SS bolts for carb bowl. Cost is about $15-$20 off of ebay.
Results seem to be good with a 45 slow jet and a 180 main jet. Shim the jet needle if necessary (in most cases you don't have to).
Hope this helps and ride hard.
If you want a kit with no trouble then here is the link (http://cgi.ebay.com/ebaymotors/FITS-...98154670QQrdZ1)
I have install a number of these with no problem if you have any question you can call the guy and ask for Sorgys he is a great guy and will help you out.
im running a dyna -jet kit on my 1200 , I drilled the slide used there spring went to a 48 slow and a 195 main and have the needle set on the fourth notch which richen's up the mid range , screaming eagle a/c and python 3 slip-ons mixture screw turned out 2 3/4turns.
Wakko47
Exhaust System Topics
03-09-2012 09:29 PM
