Need a measurement from someone with a 1200C
I just ordered some road king air shocks to put on my 2013 1200C in the spring. The road king shocks look larger in diameter than my stock shocks and since I have saddlebags (HD rigid hard mounted) I cant get to my stock ones in order to see the size difference. I just want to see what the size difference is in order to see if I am going to have any problems with fitting my saddlebags back on after I install the air shocks, since they have a molded relief that wraps around my oem ones.
Can someone with a 2011-2013 1200C that has the OEM shocks on, please try to get a measurement on the diameter of the thickest part of the shock? Thanks for any help.
I just ordered some road king air shocks to put on my 2013 1200C in the spring. The road king shocks look larger in diameter than my stock shocks and since I have saddlebags (HD rigid hard mounted) I cant get to my stock ones in order to see the size difference. I just want to see what the size difference is in order to see if I am going to have any problems with fitting my saddlebags back on after I install the air shocks, since they have a molded relief that wraps around my oem ones. Can someone with a 2011-2013 1200C that has the OEM shocks on, please try to get a measurement on the diameter of the thickest part of the shock? Thanks for any help.
