Jet sizes???
Hello all. I have a 2005 883c Sportster, bought it back in July of 2013 with 2200 miles on it. Super clean! It has stage 1 air filter, SE spark plug wires and Samson long barrel exhaust(that I have seen online). On the carb it has the easy adjust screw for the mix but with 5 turns it still farts etc. I know that is to much so I pulled the carb off and opened it up, it has a 42 and an 170 jets in there. So I want to redo the whole carb what kit and jet sizes are the best for my bike? Thank you
If you're going in, I'd replace the needle with a N65C. Don't think Harley sells them anymore (p/n is 27094-88), but they are available thru CV Performance:
http://www.cv-performance.com/cvp-n65-needle/
I would not drill the slide or use the lighter spring. Get it running right first, then you can experiment.
A 180 main will be too large (rich) for an 883, stay with a 170 or 175. SInce you're 5 turns out with a 42 pilot, I'd recommend going to a 45 pilot.
I ordered the Cv performance tuners kit for my 883, it came with 42,44 pilots ;170,175 mains. I'm running 44 pilot 175 main,emulsion tube included,lighter spring,2.25 turns out on a/f screw, hole not drilled on slide on my 883 and I Still get an occasional carb fart! but runs way better!
Wakko47
Exhaust System Topics
03-09-2012 09:29 PM
