Are these good numbers? Dyno stats
Tried to upload the dyno sheet on my Iron but I couldn't file was too large since it is in PDF format. But here it goes...
Final Tune
Max Torque=77.59
Max Power=95.35
2010 1200CC XL883
SEAC STAGE 1
Vance and Hines 2 into 1 Competition Series black exhaust
Woods Camshaft W8S
CHD HEADWORK MRW
SUPERTUNER in DAKOTA DIGITAL BOX
INDUCTION MODULE CLEANED UP TO 42MM
Contacted a few vendors to see whats the next step needed to get this bike to where it puts a smile on my face... Not that it does a bad job at it but it could be made better...
So for all you Tech Gurus, performance DIY, etc... What would you do next? Take it to a 1250? do additonal headwork, pistons, change out the cams, etc?
I would like the Torque numbers to increase for sure..
Final Tune
Max Torque=77.59
Max Power=95.35
2010 1200CC XL883
SEAC STAGE 1
Woods Camshaft W8S
CHD HEADWORK MRW
Have another go at loading your dyno chart. A picture paints a thousand words! The shape of the torque curve is everything, as that is what makes your bike move and gives it usable performance. Numbers mean little.
As an example with one set of pipes my Glide gave 102HP/103TQ. Changing pipes I got 101HP/107TQ. What those numbers do not show is the 15% extra torque I now get in the low/mid rev range. My bike is way more rideable and just plain nicer to ride now.
Received 4,225 Likes
Final Tune
Max Torque=77.59
Max Power=95.35
2010 1200CC XL883
SEAC STAGE 1
Woods Camshaft W8S
CHD HEADWORK MRW
Final Tune
Max Torque=77.59
Max Power=95.35
2010 1200CC XL883
SEAC STAGE 1
Woods Camshaft W8S
CHD HEADWORK MRW
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
great job on your engine. dyno sheet looks pretty good. If you want more power you are going to have to have all parts working as one. I wouldnt throw just cams or just a 1250 kit with it if you want to have a decent power gain. If you just throw a few things at it, i dont think youll get what you are looking for.
A hammer 1250 with their 600 cams and 1200 or xb heads with crush or sledge porting will make some serious power with a goo exhaust.
your sheet looks pretty good to me. tq curve has a nice curve to it.
here is a dyno sheet from my hammer motor with the parts mentioned above.
Carbed. It looks worse than it is. That's a wide open pull....all main jet. I'm assuming it's pipe/cam reversion.
