Comfortable seat for sportster
Old 10-16-2013, 05:19 PM
Switchback12's Avatar
Switchback12
Switchback12 is offline
I have had two mustang wide vintage seats, one on A Nightster with backrest, built for comfort. However, on a Nightster, with light duty, 11.5" shocks stock and weighting 220, putting on 12.5" progressive shocks did a lot for comfort as well. The mustang will be 15.5" wide, I think that's as wide as you will find, it will raise you up of course, I don't remember if it pushed me forward. Saddleman seats look good, just never had a chance to sit on one, they use gel in many seats.
Old 10-17-2013, 03:29 AM
Proteus's Avatar
Proteus
Proteus is offline
My (huge) Police seat has come in:
Looking for now to made my own brackets, I've blank put the seat on the bike, it really looks odd, but it should be comfy.
Old 10-18-2013, 08:36 PM
Rob Robb's Avatar
Rob Robb
Rob Robb is offline
I don't know what the underside looks like but I just made a front bracket for my stock Sportster 72 seat that I'm making into a spring seat with gel insert & leather cover. I used a 6" metal T bracket from the lumber section. Find the center measure then 3 1/2" across the top of T mark & bend 90 degrees measure how far down to drill holes for mounting at rear gas tank bolt then bend & drill mounting holes in shank of t bar to bolt to underside of seat Just get inventive
Old 10-21-2013, 09:34 AM
Vetryder73's Avatar
Vetryder73
Vetryder73 is offline
6th Gear
Default Where did you get your seat?
Originally Posted by Imold
Didn't say how tall you are, makes a big difference. At 6'3" the stock seat on my 1200C was too far forward, besides kinda rock hard. Tried a Sundowner, actually pushed me farther forward, and not very soft, either. My 883 has a Harley Pillow Look seat, very comfortable, and finally found one that fit my 1200; problem solved, sit a couple inches farther back, good cushion. Daughter says it's much nicer in second position, too. It's about 4 inches wider in back than the others. Probably won't see one on a show bike, though.
Can you share where you got your seat from? I too am a tall rider and I am looking for an alt seat for my stock seat. thanks.
Old 10-21-2013, 02:04 PM
Proteus's Avatar
Proteus
Proteus is offline
My police seat on the bike, home made brackets:
As comfortable as can be!
Old 10-23-2013, 09:26 PM
Rob Robb's Avatar
Rob Robb
Rob Robb is offline
looks like it fits the bike & it should be big enough & comfortable enough for any ones butt
nice job making your own brackets also
Old 10-23-2013, 10:12 PM
wanabe's Avatar
wanabe
wanabe is offline
after several seats on my bike, the only one that had close to unlimited butt time for both me and my +2 was the wide mustang... this one=>
Old 10-24-2013, 06:14 AM
Proteus's Avatar
Proteus
Proteus is offline
Thanks!
I had to adapt it for a better (lower) fit.
Here some pics of the bracket itself, really easy to do, two springs (from an unknown 1950's bike), some flat iron and some bolts from the DIY store:
fattyboyrider
01-31-2015 10:05 AM
Black Bettie
01-31-2014 06:52 PM
BJFLHT
09-13-2010 07:45 AM
Wide06
05-28-2008 04:18 PM
TireStud
01-04-2008 06:59 PM
Quick Reply: Comfortable seat for sportster
