Engine knock at low to mid RPM
Old 10-06-2013 | 08:43 PM
cavmedic's Avatar
cavmedic
Default Engine knock at low to mid RPM
I know there is a thousand posts on this as I've been searching for two days on this .
2009 xl1200C
The knocking sound I get is best described as someone tapping real fast on the inside of the primary cover ( kinda hollow sound) with a ball peen hammer . It ONLY happens at a certain engine rpm under load and on decel. If I pull the clutch it immediately stops. If I had to say what RPM , I'd say best guess it was between 2500-3500 RPM and only there for a few hundred plus or minus . .. ( like resonating at a specific rpm)
This isnt the normal noises ( sewing machine ,little bit of tapping , etc ) , as it sounds like it is below the top end and the best reproduction was knuckle taps on the primary case .
It's not a ping , sounds different , run either 92 or 94 ( so the pump says) , but it is definitely a knock . Warm , cold , doesn't matter.
Tonight I adjusted the primary chain and it is still there .
It's just between that one RPM .
Bike has a little over 12K .
I did see a youtube video of a guy who had a loose nut on the front gear
( compensator?) and when he wiggled the gear , it kind of had that same noise , but with cameras and computers , the sound could have been altered a bit .
I have not tried it with front brake applied and slowly putting load in it yet and having someone listen with a scope or screwdriver YET.
I have the bike going back in on Tuesday for Rocker Seal replacements as it has a slight oil seep , but before I have them on a wild goose chase for something that MAY be normal, wanted to see if I am kind of on the right path here . Especially that I have warranty ..
I've only had the bike for two weeks , first Harley , so now that im getting more comfortable with the bike , Im able to pick out some different things that I may not have heard when I first picked it up ...
Old 10-07-2013 | 01:03 AM
John_K's Avatar
John_K
If it were my bike, I'd be pulling off the primary cover and checking that nut.
Madnss (06-11-2018)
Old 10-07-2013 | 06:27 AM
cavmedic's Avatar
cavmedic
I think I may do that today. Even though it is going into the shop tomorrow for those seals , just for personal satisfaction.
Old 10-07-2013 | 06:43 AM
xFreebirdx's Avatar
xFreebirdx
Just to let you know....Sportsters do NOT have a compensator nut. Only the big twins do........
Madnss (06-11-2018)
Old 10-07-2013 | 06:47 AM
cavmedic's Avatar
cavmedic
Just a gear nut then ?
This is the best reproduction of the sound ........
Old 10-07-2013 | 08:19 AM
xFreebirdx's Avatar
xFreebirdx
Yes and yours will look more like the picture I've posted. When searching for information for your bike. You need to stay within the years model.
This is a pic showing how to lock the front and rear gears to keep them from spinning when turning with a wrench... I posted it to show you what it looks like under your primary cover.
Old 10-07-2013 | 08:49 AM
cavmedic's Avatar
cavmedic
Awesome. I started with that search but you know how YouTube searching goes. Before you know it , it's 4 hours later and your sucked into something else.
Old 10-07-2013 | 09:31 AM
cavmedic's Avatar
cavmedic
I'm just going to have the shop deal with it tomorrow when it goes in for the other stuff. I left my car keys in my wife's car yesterday and she is at work with them today. It's raining and we are under a tornado watch, I really don't feel like going out on either bike in this crap.
< feeling slightly agitated at the moment>
Old 06-11-2018 | 11:17 AM
johnny_bravo00's Avatar
johnny_bravo00
Resurrecting this old thread. Recently heard what it sounds like OP is describing. Sounds exactly like what OP wrote in the original post " knuckle taps on the primary case". Does not sound like it has anything to do with top end misfire, etc. Anybody else have a sound like this > low rpm under, slight load < ?
Old 06-11-2018 | 06:06 PM
apache snow's Avatar
apache snow
Did you pull the primary cover to check things out?
Quick Reply: Engine knock at low to mid RPM
