Lowering ??
Old 09-29-2013 | 11:48 PM
TxFF636's Avatar
TxFF636
Default Lowering ??
Ok guys I need some suggestions on lowering my wife's Iron about an inch. Would you go with Burly 10.5 shocks or world you go with one of the cheap lowering brackets? Just curious what is the best route.
Old 09-30-2013 | 12:49 AM
PanHeadRich's Avatar
PanHeadRich
10.5" shocks will ride like a ridged frame. 11.5" are bad enough, but 10.5" will be spine jarring. IMO Lowering Blocks would be the better option being that they won't reduce the amount of travel in the shocks.
Old 09-30-2013 | 12:53 AM
ryanjames170's Avatar
ryanjames170
ill second that about the lowering blocks
Old 09-30-2013 | 01:11 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I have used lowering blocks on multiple bikes, including my Sportster. Made for a much better ride.
Check out some options HERE.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
Call/Text: 662-252-8828
Old 09-30-2013 | 09:06 AM
201348hd's Avatar
201348hd
I use lowering blocks. No issues thus far and the ride is about the same as stock
Old 09-30-2013 | 09:32 AM
Kontankerous's Avatar
Kontankerous
If you go with lower brackets, get solid steel ones (you're putting a significant amount of force on these especially with the change in geometry), not some cheap *** molded/cast or welded bracket/block.
Old 09-30-2013 | 10:24 AM
Jester 08 Nightster's Avatar
Jester 08 Nightster
DK's lowering blocks are on my bike. Talk to Kevin @ DK, he's got tons of miles on his.
Old 09-30-2013 | 10:37 AM
Sweforty8's Avatar
Sweforty8
I'm riding on Burly 10,5" and I'm very pleased with them. Yes they're stiff and all but it depends on what you/your wife is after. Lowering blocks will off course do the trick if its only the "lowering" part you're after. And they're also more cost efficient.
I've got no experience with lowering blocks my self but I would trust the other guys in here who do use them! I would think that you will have a softer riding experience with the org shocks and blocks compared to the Burly shocks.
Old 09-30-2013 | 11:24 AM
TxFF636's Avatar
TxFF636
Thanks so much for all the replies, it helped out a ton.
Old 09-30-2013 | 04:11 PM
grbrown's Avatar
grbrown
I wouldn't let lowering blocks anywhere near a bike of mine! Start by ensuring your wife is getting good reach with her legs and feet. Trimming the nose of the saddle to ease the line her legs take can improve reach noticeably and Harley, plus other brands, make sturdy high heeled riding boots, which will give her a good grip as well as improving her reach.
Quick Reply: Lowering ??
