Does anyone else mark bolts on their bike?
Old 09-25-2013 | 08:05 AM
South JerseyJoe's Avatar
South JerseyJoe
Yup, been doing this for years. I use a paint marker it does the same thing. Just a quick glance will tell you. I use the 6 o'clock point on just a few critical fasteners.
Old 09-25-2013 | 09:59 AM
johnjay's Avatar
johnjay
I'll do it if the bike goes in to the mechanic just to see if the work was done...or atleast attempted. Same goes for car tires being rotated.
Old 09-25-2013 | 06:03 PM
c0jones's Avatar
c0jones
I use Marsh 88fx paint markers @ work.
Instead of marking a certain spot,
we make a line from the nut/bolt onto the part/material.
Old 09-25-2013 | 06:28 PM
Pagan48's Avatar
Pagan48
Very common on aircraft. I used this product on aircraft for years.
Called Torque Seal and as you can see it comes in a variety of colors. Couple bucks a tube.
Old 09-25-2013 | 06:34 PM
Gliden's Avatar
Gliden
I safety wire every bolt head and torque stripe every nut on my CH 46 helicopter.
I don't do that on my bike.
Old 09-25-2013 | 06:38 PM
elfnyc's Avatar
elfnyc
i use those little paint pens, but i dont mark every bolt.
Old 09-25-2013 | 06:41 PM
Junkster's Avatar
Junkster
I do this on the sprocket bolts given the issues some have had with the bolts shearing off. I place a blue dot from a sharpie where the bolt meets the sprocket face.
Old 09-25-2013 | 07:20 PM
Uncle Larry's Avatar
Uncle Larry
I've got the safety wire pliers and the stainless steel wire and I still use it from time to time, especially on parts inside the primary on the old scooters.
Old 09-25-2013 | 07:57 PM
Afghanvet_2x's Avatar
Afghanvet_2x
Attachment 335159
This what I use, Just on real important stuff like motor mounts, axle nuts brake calipers
Old 09-25-2013 | 08:03 PM
Rob Robb's Avatar
Rob Robb
yes, I use a Sharpie, little dots, color matching my bikes ( I have two bikes). It doesn't come off unless you rub hard with metal polish & gives me peace of mind. Thou I've not had any come loose that I've torqued to specs using blue lock tite
junkyardscrounger
10-12-2016 10:09 PM
deadhawg
General Topics/Tech Tips
10-16-2015 12:26 AM
forever young
03-22-2009 10:03 PM
Pitts2112
12-26-2008 05:19 PM
reddfoxharley
09-04-2007 09:36 PM
Quick Reply: Does anyone else mark bolts on their bike?
