Damn brake light
when reinstalling your front brake levers you have to make sure it is pulled in and slightly away from the switch or you can damage the new front brake light switch putting it on dealer does it all the time they said I did it to mine had to buy another switch and be very careful making sure I did not hit it with sliding my front brake lever back together
Negative ghostrider; in that area a 12V+ signal to ground would cause a dead short and blown fuse...his brake lights are staying "on" so it's got to be a switch/switch wiring issue.
=8^)
I have same type of issue on my 09 nightster.I have narrowed it down some.If I disconnect the rear brake by pulling of the wire off ,the blade connector down down in front of the rear wheel,the lights work the proper way except the rear brake used by itself doesn't light doesn't of coarse.
FLYING_BURRITO_BROTHER
09-03-2020 01:03 PM
