HELP!! 08 Nightster
Old 09-17-2013, 04:28 PM
nighty0619's Avatar
nighty0619
nighty0619 is offline
thanks - didn't think Loctite was a good idea. but wasn't sure if this is a common problem that they come loose often
Old 09-17-2013, 04:41 PM
hagger's Avatar
hagger
hagger is offline
Might be a good idea to go around & check the other fasteners on the bike too.
Old 09-19-2013, 05:39 AM
fissco1234's Avatar
fissco1234
fissco1234 is offline
Disconnect the ground wire from the engine case when removing the battery. Torque the connection at battery negative to 70 in./lbs, with the cable pointing downward. Slide the battery back in while fishing the negative cable back through the frame and reconnect it to ground, attach and torque the positive cable to 70 in./lbs as well. It's a pain to do it this way, but because of the way the battery is positioned, and the short cable on the negative terminal, the connection will turn ccw every time unless you give yourself some slack.
Old 09-19-2013, 07:33 AM
Otter's Avatar
Otter
Otter is offline
I would start with checking/replacing both of your relays, cleaning all of of your fuses, and cleaning/tightening your battery connections. I bought my 08 Nighty second hand, and after I started having some problems I checked the fuseblock and it looked like a chinchilla from all of the corrosion. Performing the above fixed the problem for me. Clean all of the fuse blades, blow out the fuseblock with air and wf-40. Use generous dielectric grease in the block as you put them back in.
Old 09-19-2013, 08:03 AM
fissco1234's Avatar
fissco1234
Yours too? Same bike, same find. What caused it I wonder?
Old 09-19-2013, 08:23 PM
okbill's Avatar
okbill
okbill is offline
Don't think of it as a stupid mistake, take it as a lesson learned!
Allen PapaLanky Eirich
09-08-2018 08:01 PM
Meanface
06-15-2014 08:42 PM
Woodchuck
05-21-2012 10:32 AM
02HarleyDJV
09-07-2011 09:12 PM
02HarleyDJV
08-30-2011 06:58 PM
Quick Reply: HELP!! 08 Nightster
