front wheel bearings broke
Old 09-13-2013 | 08:31 PM
Dirty Bob's Avatar
Dirty Bob
Default front wheel bearings broke
How many miles should the front wheel bearings last? My bike has the 21 inch laced front wheel and I have 31 k + miles on the speedo. Three months after Harley Service mounted a new front tire the bearings crushed.
Old 09-13-2013 | 08:37 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
I don't have that answer for ya, but I'd probably change the bearings along with the tires. They're fairly cheap, and if you're having the dealer pull the tire they've got a fancy bearing puller.
Old 09-13-2013 | 11:21 PM
rich1374670x's Avatar
rich1374670x
16,400 on my front bearings with a 21 inch wheel. Tires changed at 15,800 miles.
Old 09-14-2013 | 06:20 AM
cHarley's Avatar
cHarley
The type of wheel bearings used by HD has changed 3 times since 2000. You're question can't be answered without knowing what year bike you have.
BTW, my front bearings have over 90,000 miles on them.
Old 09-14-2013 | 11:34 AM
Rob Robb's Avatar
Rob Robb
I've never had front bearings go bad in 48 yrs of riding all makes of bikes probably because I re-lube them every season along with everything else I service. Best advice "learn to service your own bike"
Old 09-14-2013 | 11:46 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Harley has used sealed bearings since 2000, they are not designed to be serviced. If you remove them, they are ruined.
Explain how you are servicing sealed ball bearings.
Old 09-14-2013 | 02:55 PM
parabellum_9x19's Avatar
parabellum_9x19
Lots of talk about the recent HD bearings being made out of cheese and dying early.
I have a set of all ***** racing bearings just waiting to go onto this bike, the only thing is you pretty much have to have the HD bearing puller/presser unless you already have another bearing tool that is suitable.
parabellum_9x19
I'm picturing him squirting oil on a sealed bearing.
Old 09-17-2013 | 09:32 PM
Dirty Bob's Avatar
Dirty Bob
OK, good question. I have a 2009. These bearings like most of the parts are 2008.
Old 09-17-2013 | 09:40 PM
Dirty Bob's Avatar
Dirty Bob
This is the same thing I was thinking, replace any failed parts with best quality parts . I'm not familiar with all ***** racing bearing but I'm already a fan.
Quick Reply: front wheel bearings broke
