07 Custom - After Market Pipes?
Any suggestions for some after market pipes on an 07 Custom Sportster??
I was told that there were no after markets available, only the screaming eagles that would keep the warranty intact.
This was a while ago, so maybe V&H or someone has come up with the required technology for the fuel injection.
Any thoughts??? Thanks
[/align]
RE: 07 Custom - After Market Pipes?
the part about no aftermarket pipes is BS.... the part about a possible void of warrenty ...thats true, but everyone goes through it....
I'm in the market for pipes also.... Harley screaming Eagle pipes are good for performance but not much extra harley loudness if thats what you want...
check out.... Vance & hines........ Rinehart...... or cycle shacks....
Click below for the Vance and Hines ShortShots on an 07.
http://s154.photobucket.com/albums/s262/barrydavis_photos/Vance%20and%20Hines%20ShortShots/?action=view¤t=vanceandhines.flv
They can't void your warranty unless they can prove the aftermarket part caused the failure.If you burn a hole in a piston from being too lean they probably could.If your trans or a wheel bearing goes bad how could they.By the way just replacing the mufflers won't make you go lean.I always save my old parts in case it needs to go back to stock for warranty purposes.The dealer sold me my vance and hines so if they void my warranty heads will roll.They made no mention of it possibly voiding my warranty.
Heybdavis, was that with the baffles in?
Do you think the slip-on's would sound some what the same?
I'm not sure about the slip-ons. I haven't heard them, but I'm pretty sure they would sound good. I just prefer the look of the full pipe.
I added the SE air cleaner when these pipes were put on, plus the remap. It is noticeably more powerful than before.
BTW, that video doesn't even come close to doing justice to the sound of these pipes. They are MUCH louder and MUCH smoother than the video would lead you to believe.
Barry
Just did a search on Ebay, for an 07 with the 02 sencor port welded in, $265.00 plus $12.00 shipping. Does that sound about right?
I don't pick up the bike until Friday and allready have a pile of parts to put on it.I have a few weeks before I can ride it, we got snow, salt and sand on the streets still.[:@]
Brian
Brian
ORIGINAL: bdavis
If that is for the full set of pipes I'd say it is a pretty good price.
Barry
Barry
Brian
