turn signal, kill switch, highlow, and horn buttons
Hey all,
I am working on bobbing out my 09 Nightster. I currently have 16 inch apes and am changing out to a jockey shifter with suicide clutch. In an effort to clean crap up I am also trying to remove the bulky plastic switches for blinkers and horns and kill switch etc. My question is: does anyone have ideas on where to relocate these? I don't want to lose functionality of the blinkers and switches so I was thinking of routing wires through bars and changing our blinker switches to smaller buttons on the bars....but the kill switch and horn and start button will need to go somewhere...most likely on the frame. Any ides are appreciated...In the end the only thing i want on my bars is a fron brake, master cylinder and mirror mounts upside down. And a nice set of old skool grips Thanks!!!
moved my headlight switch to the brow. got rid of the front blinks and mounted tiny posh mini switches on the bars for those. can barely see them. starter switch and horn on the neck gusset. removed the kill switch so pump primes now when I turn the key. I have pics if you want them or check my profile pics or the crazyorange m/c thread I started but that **** is like 1k pages long. lol. good luck.
I have seen several designs that also relocate the switches to the ignition mounting plate and some use an auto type ignition to eliminate the start switch. As long as you use a high quality switch that is made for outside rough usage and rated for the amps you will be drawing.
Nice setup bmxatv looks awesome and nice and clean love the bars and riser clamp kool.
Cheers
Cheers
Hey all,
mtiberio
05-27-2014 08:02 PM
