drive belt adjustment
intersting post as ive just put my rear wheel back on after having a new tyre fitted. I tensioned mine on a jack with wheel off the ground, surely this is the correct way as if its on the jiffy stand how can you move the rear wheel foward or backwards on the adjusters to set tension??
when i had my rear wheel central i adjusted the adjusters evenly untill my drive belt was the same tension(using fingers) as before. I felt a friends belt on his 48 and his was much looser than mine but he has lots more miles on his and as said mine feels the same tension as before and i bought new in 2012 so thats how it came.
You can do it on a jack with the rear wheel off the ground on Touring models. Just set it to the loose end of the adjustment specs.
With my wife's Sportster I put the rear wheel on a cheap Harbor Freight wheel roller and have the front wheel in a chock. That way the bike is bearing its own weight and I can spin the wheel to find the tightest part of the belt.
