Sporty Tail light Question 07 custom
RE: Sporty Tail light Question 07 custom
I have the same question. \\; I am guessing that you are talking about the brake light modulator which makes the brake light flash several time before going to solid. \\; I have the taillight conversion kit installed on my 2008 Sportster which makes the turn signal lights also work as running and brake lights. \\; I would still like to have a modulator added because it does grab the attention of drivers behind you. \\; I had a modulator on my Honda Shadow and it worked great. \\; I am just a bit hesitant to go splicing into wires without knowing for sure that I have the right one.
Should be the R/Y (Red w/yellow stripe) \\;\\\\\\; See below for breakout:
There are six:[*]O/W (orange/white): Accesory position ignition switched power feed[*]BN (brown): Right turn signal[*]BE (blue): Ignition on position ignition switched power feed[*]R/Y (red/yellow): Stop light[*]V (violet): Left turn signal[*]BK (black): Ground
[ol][/ol]
[ol][/ol]
hhkiwi
04-15-2015 03:41 PM
koresample
02-09-2015 10:38 PM
