Just did a tank swap, have some questions.
Like the title says I did a gas tank swap on my 05' sportster. I went from a 3.3 to the 4.5. I noticed right away that the 4.5 sits lower because of the larger size, and this cause some wires and hoses to be pushed down. I attached a couple pictures so you can see what I'm talking about. The gas line from the petcock is pressed down and the spark plug wires are also pressed down and touching the top of the motor. I don't recall if the wires were pressed down before the swap or not. Does any of this look like it could cause a future problem? Thanks for any help.
I was able to lift the tank back up and tuck the wires in better. It seems to be fine now. The gas line is pushed down but it's not pinched. I'll see how this works for a while but if I notice any problems I'll have to do a lift. I'm trying to avoid a lift because I'm trying to get the most capacity from my tank.
ziggymotion
Exhaust System Topics
09-03-2007 10:58 PM
ziggymotion
09-03-2007 08:34 PM
