Bike just clicks wont start
Old 08-02-2013, 02:17 PM
Booey424's Avatar
Booey424
Booey424 is offline
Did it just click once, or is it clicking as you hold start button?
Mine would click once and then nothing. It was blowing the fuse. It turned out to be a wire shorting out in the headlight.
Old 08-02-2013, 06:28 PM
WarriorHD's Avatar
WarriorHD
WarriorHD is offline
This is good information. I never knew there was a difference between a trickle charger and a battery tender.....
Originally Posted by cHarley
A Trickle charger should not be used to "maintain" a battery, it will literally cook the battery.
You should use a Float charger which is often referred to as a Battery Tender.
Old 08-02-2013, 07:31 PM
abeldiazjr's Avatar
abeldiazjr
abeldiazjr is offline
cHarley -
Good catch. I'm not trying to put out bad info. I guess I just never knew its real name. The dealership gave me mine when I purchased the bike and in the winter, the Sporty that goes down for maintenance gets the tender.
I went ahead and updated the posting.
Old 08-05-2013, 08:47 PM
Frank Gomez's Avatar
Frank Gomez
Frank Gomez is offline
Stage III
Any suggestions on the battery tender brand I should use? Are the ones they use at Auto Zone safe?
Old 08-06-2013, 09:08 AM
thelaststrum's Avatar
thelaststrum
thelaststrum is offline
1st Gear
Mine did this a lot last season, it ended up being the ground cable connection at the battery terminal. I used copper wire to make a better connection, because cleaning it did not work and it actually began to melt the terminal a bit.
Check fuses as well, as I had one that was blown.
Batteries Plus is one suggestion for a reasonable battery.
Good luck!
Old 08-06-2013, 09:44 AM
Nans94's Avatar
Nans94
Nans94 is offline
Originally Posted by mikek87
and if this doesn't work break out the bfh ( big fing hammer) and go to town. This is usualy my tool of choice when things don't go right.
lmao !!
Old 08-07-2013, 12:11 PM
abeldiazjr's Avatar
abeldiazjr
Don't know about Auto Zone but my H-D tender does the job. They run about $30 bucks. Hell, CycleWorld puts out pretty good products as well.
Nitro Joe
Electrical/Lighting/Alarm
05-04-2018 04:25 AM
Iarecobra
06-12-2014 06:21 AM
BadMetal705
12-23-2011 02:18 AM
bandit2
08-24-2008 11:18 PM
riles10
24
03-30-2007 06:14 PM
Quick Reply: Bike just clicks wont start
