problems after baffle removal
Hey guys, I removed the baffles on my 02 sporty (se2) and liked the sound, a little deep but good. Rode great for a while then it bogged out on me and I was stuck after that, it ran after sitting for a while again for about 2 weeks, now its out again and wont start . cleaned the carb beginning of summer so I imagine its back pressure loss causing bad air fuel ratio. So I am planning on getting big city baffles and jets, thinking that is the peoblem of course. Id rather not get the baffles and just get the jets for it. Does any one have good suggestions and also what is that sensor that one of my breather hoses from my carb goes into? Does that need replacing ?? Any help would be great guys
JSport, removing the baffles shouldn't have made your bike die. But you gotta put out more info. Is it not starting, do you have any power? Gotta run through everything, check battery, fuses, switches. If you have no power. Or do you mean it's just running weak without the baffles?
