sporty with 180 rear tire?
Do any of the newer sportys come with a 180 rear tire? I'm looking into modifying my 2000 dyna with 150 to accept a 180 but i need a wider fender. I want to stay with a similiar styled fender as what is on the bike now in my signature. I know a 06-09 dyna fender is wider than my 00 but they are going pretty high on ebay. I keep seeing similiar styled sporty ones on ebay for half as much. i just need info on how wide they are.
Deleted... did not understand the question... you are looking for a fender solution...not the wheel/tire combo... back to my cave...
This is what was used on the newer sportster by fellow forum members to install a 180
https://www.hdforums.com/forum/sport...sion-pics.html
(2) 9276A BEARING (NON-ABS)
(1) 41430-09A WHEEL ASSEMBLY, STEEL 17 IN., W/O BEARINGS AND SLEEVES (BLACK)
(1) 41242-08 SPACER, AXLE - RIGHT, NON-ABS
(1) 40947-08A SPACER, AXLE - LEFT
(1) 43905-08 SLEEVE, SPACER BEARING
(1) 41319-10 RIM, STRIP 17 IN.
(1) 41314-10 INNER TUBE, TIRE 17 IN.
(1) 41123-79 CAP, VALVE
(1) 54321-85 NUT for valve
(1) 43200011 TIRE, 17 IN. - Michelin 180/55ZR17 Scorcher 11 - 17"
(1) 3mm spacer
(1) 3mm spacer
Check out this link. It should answer your questions.
http://www.harley-davidsonforums.com...-fit-dyna.html
EDIT: Scratch that. I just realized you are looking for a fender wider than stock. Is it Friday yet?
I've found a wheel that'll work for a 180 tire. I plan to do a chain conversion to free up more room. I just need a wider fender that I can modify and then get painted. between my struts is about 7 1/4 inches or so. I plan to make some modifications to squeeze in a fender that is about 8 inches wide.
I'm not exactly sure yet. It depends what fender i go with. I want to be around 8 inches wide. Some of the newer dynas have a 8 1/2 or wider fender. I've thought about putting a bottle jack between the truts and spreading them. Maybe heating them. I've also thought of grinding the welds and taking the truts off and either welding them back on a little wider or fabbing new truts of some sort. Still planning at this point and hunting for a fender that I like and that will work. Obviously the fender I get will need to be fitting and all new mounting holes drilled, the old holes filled, and then repainted. I plan to use a 02-04 or so v-rod rear wheel. 8x5.5. I'll need to get reducers and new 3/4 inch wheel bearings for it to work.
Maybe send these guys an email, possibly would have a fender you could buy..
http://www.chopper-kit-usa.com/fat_t..._sportster.htm
