I obtained a 3.3 tank for my 48, so I'm going to swap it out myself later this month. The process looks straightforward in the service manual, but I thought I'd ask if there is anything I should look out for when doing this? Thanks!
Its an easy job. Its two bolts, the fuel pump plug and a fuel line. Make sure to put a rag under the fuel quick connect as it will drip a little gas out when you remove it.
