Sporty Grips
Sporty Grips
I have aftermarket grips for my Sporty, I love them but realize they are not like the HD OEM grips. I know I must glue the left clutch grip, do I just butt-up the grip to the switch housing? The OEM grips actually are held by the housing & my aftermarkets will not fit inside (Large Lip). Also I had to order a throttle sleeve for the right side, do I glue the new grip onto the sleeve? ANY info will help, Thanx!
Ron
You can do whatever you want with the left one. Just choose your route carefully if you ever wanna get the thing off. Right one, I slid my grip right onto the sleeve. But mine are rubber, probably different. You may as well glue it, should probably just change the sleeve with the grip later on anyway.
