2013 48 handlebar swap
any bar over 8"s tall will need a longer brake line. 10" bars and under you will still be able to use all of the other stock cables. I have 10" bars with 1" risers and only had to replace the brake line. You can get a "build your own" steal braided kit through Magnum Shielding for around $55.
Thanks,
I have read that in several places but I just don't see how a 8" bar would work with the stock brake line. Do the earlier model 48's have a different brake line?
Mine has about 6" of brake line down to the handlebar mount then goes to a rigid metal line to under the fork bracket then back to brake line to the caliper. I don't see much slack in the top portion of the brake line, pretty tight on the stock bars.
Idk, just don't see a swap without a new brake line.
The 48's; maybe other Sporty's; come with the metal/rubber brake line. A steal braided line will be much better. Best bet is replace it. Rubber expands with brake pressure and reduces stopping power. Steal braided wont. A cheap and much better replacement. Don't try and bend the metal line, that will make it weak and you will have a chance of it cracking under pressure.
Those are really nice but way out of my budget.
I think I will just go with the keystone bars. Should be safe on all the cables and wires and I do like them better than the frisco bars. For some reason I thought the keystones had more pull back than 2".
