Damaged Finish
Old 07-01-2013, 02:11 PM
W1ldC4t's Avatar
W1ldC4t
W1ldC4t is offline
Default Damaged Finish
So I got on my bike the other day and noticed that my handlebars looked a little different. I have Biltwell Z bars (black) that I installed about 6 months ago.
When I looked at the bars I noticed that the finish on them looked cloudy. Since I store my bike outside, I thought they were just a little dirty. Upon further inspection it became clear that they weren't dirty, but actually "damaged." They aren't shiny, dark black any more, but now a little clouded, and dull.
I had cleaned my tank with Windex based on some posts on this site (and it worked awesome on the tank). I had also used Simple Green to clean the engine a week earlier. I didn't use them in combination, or even within 48 hours of each other.
Has anyone else experienced this? Know of a fix (if there is one--though I doubt it). Anything else I should know going forward?
Thanks for your input, it would be great to hear what you all think.
-Wildcat
Old 07-01-2013, 02:31 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
You should never use Windex on your paint...... Period. It is ammonia based.
Are you sure it wasn't Lemon Pledge that many of us use on our bikes?
Old 07-01-2013, 02:37 PM
88XLH_DLX's Avatar
88XLH_DLX
88XLH_DLX is offline
IMHO, Windex is a horrible idea when it comes to cleaning any painted surface because it strips off any wax and leaves the paint dull and unprotected. If left unprotected for a while, the paint may be oxidized. First thing you would have to do (depending on how bad it is) is compound or polish, then wax the paint.
Old 07-01-2013, 02:57 PM
Kontankerous's Avatar
Kontankerous
Kontankerous is offline
wait...dude has an iron. that paint is very different than the others. it's a low satin/flat single stage urethane base. windex won't hurt that at all, although I recommend just a soft sponge and warm water only. What ever you do, do NOT put wax on the irons paint. it'll turn into vivid black.
Old 07-01-2013, 03:09 PM
xFreebirdx's Avatar
xFreebirdx
That could be the reason that just his bars have a white hue to them now.
Old 07-01-2013, 03:26 PM
Kontankerous
ahhh...i really can read...sometimes
Old 07-01-2013, 04:18 PM
W1ldC4t's Avatar
W1ldC4t
W1ldC4t is offline
For clarification: I used the windex on the black denim tank only (though, perhaps some of it got on the bars). My suspicion is that the ammonia got on the bars (which are a glossy black color) and has damaged the paint there. I will try to get some polish on them and see if it helps.
Thanks for the replies!
Old 07-01-2013, 04:21 PM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
I would imagine the bars are powder coated. Unless they had a bad batch of powder or an improper cure cycle, anything less than acetone should be OK. If they're really 'efed up, maybe Biltwell will warranty them.
I have a satin black powder coat on my Sportster's handlebars. They can get a little dull looking from sun, dirt, etc. After washing with soap and water, I hit 'em with a little Meguire's Quick Detail or 303 Protectant (my favorite) and they spruce up nicely. I feel the satin black replicates the factory finish on the switch housings, clutch perch and front brake master cylinder better than flat or gloss black.
You can see a slight difference between the handlebars and the speedo housing, which is powdered with gloss black (gas tank is factory paint, Vivid Black).
A flash exaggerates the difference:
Old 07-01-2013, 04:24 PM
eXs FireCat's Avatar
eXs FireCat
eXs FireCat is offline
Spray the windex directly on the paper towel and not on the tank, this will prevent any further cat kicking
Old 07-01-2013, 04:28 PM
W1ldC4t's Avatar
W1ldC4t
W1ldC4t is offline
HarleyScuba's 2nd picture with the flash on is exactly the kind of discoloration that I have.
eXs Firecat--good call on spraying directly onto the paper towel. I will keep that in mind next time. Thanks for the tip.
Quick Reply: Damaged Finish
