Okay Running 89 Oct?
Your motor's octane requirements are dependent on a number of factors, compression ratio being a big one. The 1200's higher compression ratio (9.7:1) has always required higher octane.
Have you ever wondered why in some parts of the country, 91 octane is the highest octane pump gas available, while many others have 93? Cooler temperatures and higher elevations (thinner air), reduce the engine's need for octane.
In the hot summer months at near sea level, 93 octane is a must in mine. In fact I also retard the timing 2* as well to completely eliminate detonation (pinging).
But, when I'm in the mountains during the cooler months of the year and at elevations above ~2500 ft, my bike runs great on 89 with no retard on the timing.
But like you implied, to save $1.00 per fill-up?
Received 1,297 Likes
I've run 89 in a '07 Nightster since it was new. Never had any problems even in 100+ temps. Actually get about 1 - 2 mpg better with the 89 instead of the premium grade. My experience with carbon build-up is that it tends to happen more with running too high an octane because the higher octane has a slower burn rate and that can cause incomplete combustion.
