Does anyone know if the CD LED's ever go one sale? Is there a good alternative? Im sure its a great product but, $70 for only two LED's is a bit expensive.
If you search the net they can be found $10 or so cheaper individually, but if you buy a complete kit direct from CD that consists of the LED's for the front and rear [choices: amber, red, Moon Shinez™, Dynamic Clusters2™, Dynamic Ringz™], plus the lens' of your choice [choices: clear, smoked, amber, red] and the required load equalizer, it's less $$ overall. BTW the LED clusters do have a lifetime warranty. The whole system is easy to install and you'll be impressed with the quality and amount of light these clusters throw out. The "Dynamic Ringz™" I chose for the front are like additional driving lights and the raspberry-ruby red taillights are just bangin'...and with clear lens', all that color is free to bLaSt out in your face...you won't be disappointed I assure you. These things should be required by law ;O)
Check out the kits, 'down towards the bottom of this page:
Custom Dynamics will have a booth set up at a local Harley store next weekend. They are having a big party with lots of vendors. I plan on stoping in and talking to them. I plan to pick up a full kit or order one for my bike. The incandescent stock bulbs need to go!
I have the dynamic rings in the front and clusters in the rear on a 11' 1200c. Load equalizer is a biketronics. I've had no issues for 2 years with either. The load equalizer fits nicely under the seat, all be it I have a mustang vintage and tucked nicely. No power required and it just plugs between the wire harness with the correct ends and are Installed. The only problem I had was with the clusters in the rear, I got the run , brake turn and with the service manual tying in was my issue. Don't know which was wrong, manual or bike I had a back feed issue. On the rear the socket post was neutral and the side was hot, opposite from what the front was. On the dynamic clusters I had to cut the wires and swap them, after that no issues with a the back Feed and every thing worked. Don't know if it was an HD mistake or a customs issue on quality control with the wiring. I've had many compliments with them and actually got pulled over because of them, the police wanted to know where I got them lol. Find out the part number through CD site and look for on amazon. Powersports on amazon is $20 cheaper and there in just a few days, same with biketronics.
