Custom Dynamics LED report...
06-28-2013, 08:23 AM
Ahhh. I Got It. Thanks For The Clarification! While I Like The Solid Light Up Of The Moonshinez, I Dont Think That Would Pass VA Inspection.
06-28-2013, 09:22 AM
Quote:
Originally Posted by
DrewBone
Some pics as requested:
=8^)
Very nice... I picked up the EclipseLED
(front amber run & turn) and Dynamic Clusters
(red turn/run/brake) but haven't had a chance to install them yet. Tested one of the Eclipse and it is definitely much brighter than OEM... blinding at close range.
(BTW - got them from Phat Performance for a little less than direct.) Will be using clear lenses as well.
07-02-2013, 07:43 PM
09-23-2013, 08:19 PM
Do the rear red led lights work with the run/brake /turn module(69463-06a) without a load equalizer if i'm only running leds in the rear?
edit=bought led lights separate from module , will they work together?
09-23-2013, 08:26 PM
I've had my CD LED r/s/t lights for about 5-6 months and love them. Vey bright and well worth the money. And a great company to do business with. I'd do it all over again and would steer anyone who asks, to go with them.
09-23-2013, 09:42 PM
i also have the front dynamic rings and rear reds !! will never look back , great buy, suuuupppper bright easy install !!
i also went with the cool smoked lens for the front
old video - i changed a few things since this one
09-23-2013, 11:36 PM
do these just replace the stock bulbs or do you have to do other modifications to put them in?
09-24-2013, 12:50 AM
If you do both front and rear you'll need a load equalizer to make them flash at the correct rate.
09-24-2013, 05:38 AM
I have installed just the rear led lights will they work with module(69463-06a)run/brake/turn ??
09-24-2013, 06:24 AM
chris h.
Thanks. Does it also replace the chrome housing inside the turn signal mount or do you leave that in place?
