Reconnecting the horn
If your battery died after trying to blow the horn, you have other issues. It does not matter what connection you put on what horn connector, it works either way. If it was faint it was because your battery was already dead. Have you had your bike stored for awhile and didn't have it on a battery tender? Are your battery connections clean and tight? Did you have your key turned on and left on for quite awhile? There is some other reason that the battery was dead, not because you hooked the wires on the horn in the wrong place (as there is now wrong way to connect it).
Ross McDonald
10-18-2019 05:35 PM
Born4Booze
Electrical/Lighting/Alarm
03-20-2017 10:34 AM
