Rocker Box Covers - DIY or Dealer??
I got my bike two weeks ago... I got the black rocker covers but forgot to negotiate the install from the dealer as part of the deal... stupid me...
Reading many other threads on the subject... should I pay the dealer to do the install or should I give it a go and do it myself??
I have the covers and four new gaskets... I just don't know if it is worth saving a hundred bucks or pay the dealer to do the install and provide the warranty on their work...
Mine look to be in perfect condition... mating surface looks clean and like it was worked after the powdercoating was done... not like some that I have seen on other threads where they had to use a flat surface to sand down the mating area.
Also, some say to install dry, others to use some sealer... working around cars I have some loctite 574 that it is use when sealing two metal surfaces that use no gasket... I wonder if that would be the way to go in addition to the new gaskets to be on the safe side avoiding leaks??
If you're just changing the top cover, you should be able to easily do it yourself. I'm sure someone here can give you the torque for those four small bolts, it can't be much torque at all. The hardest part is getting at the bolts, I think you might need a "shortened" hex wrench to access one of them.
John
John
Thank you for the suggestions! Too bad about not doing my homework ahead of time. Wasted the money on the stock gasket. Ordering some cometic gaskets... heck JP Cycles has them... I can ride and get them...
http://www.jpcycles.com/product/434-474
Hey Wachuco!
I am about to tackle this exact swap. Would you mind sharing any insight on any potential issues or steps I should be aware of? Also would you mind sharing the torque specs on the 4 bolts, tightening patterns, etc?
I plan on getting a service manual but don't have one as of yet.
Thanks in advance!
Thanks in advance!
Hey Wachuco!
Thanks in advance!
Thanks in advance!
So I took a few days off from work to spend with family visiting... today they wanted to go shopping, and knowing how much I like to do that... I decided to stay home and swap rocker covers for the black units I had.
I removed the tank following this thread. Excellent videos.
Removing EFI fuel tank (How-To Video)
With that, tank is off!
The rest was removing the plastic covers, undoing the plugs, everything needed to get the necessary space to lift the covers and replace them.
There... front is clear and ready to go:
Front cover removed
Reading the manual just in case...
New gaskets in place, cover in place, hand tighten the bolts, used a hex wrench to screw those in enough to start using the torque wrench. Started with 50 inch-lbs, then 75, 100, 125... books says 120-165... no way I could have done more than 125 on these... I hope that the book had a torque range and was not asking me to take them to 165... I was afraid they would break if I did that...
Front done
On the rear, there was a suggestion to wrap a towel around the frame to avoid scratching the new one. I had plastic from the new covers, wrapped that around with some tape... rinse and repeat... only thing with the back is sliding the sensor wire through the gaskets and then through the cover... but it was easy. As I was putting down the cover I kept looking to make sure the gaskets were in place and had not lifted...
rinse and repeat... torqued down to 125 inch-lbs... in increments...
Front cover removed
Front done
