Engine Noise while riding
Old 06-03-2013, 12:28 PM
blackknight883's Avatar
blackknight883
blackknight883 is offline
This is the noisy sportster EVO motor guys. If I tuck my legs tight to the tank the noise goes away. Its just the top end of those motors are noisy.
Old 06-03-2013, 02:09 PM
Mich's Avatar
Mich
Mich is offline
I agree with this. There is no mistaking pinging or detonation. It is quite loud when it happens, sounds like someone is hitting the cylinder with a hammer. All the sportster motors are basically the same and a different sized tank is not going to hide the noise of detonation.
Old 06-03-2013, 02:23 PM
Jester 08 Nightster's Avatar
Jester 08 Nightster
Jester 08 Nightster is offline
Hmm, I believe I've been experiencing this. I honestly thought something was loose on my scoot because of the vibrating metal screech sound but couldn't find anything.
The detonation theory may actually hold water for me because my bike normally only does it after some stop and go traffic on my afternoon commute. I come off the highway and have about 5 minutes of 10 - 15 mph traffic with stop lights. Then when I finally get some room to open it up it makes the noise.
I only have an exhaust with stock a/c but maybe some X14ieds will cool things down enough to eliminate the issue?
Old 06-03-2013, 04:11 PM
parrishbjj's Avatar
parrishbjj
parrishbjj is offline
Well, after alot of reading on the net, im thinking it is detonation. I believe i have stock pipes on my bike but someone either took out or drilled out the baffle. I get a lot of backfire on deceleration. Considering these bikes are lean to begin with, and then the baffle gone, Im thinking that is my problem. TOO LEAN... I hope that is it. I will be ordering a new exhaust, intake and tuner.
Anyone recommend a tuner? Just want to be able to get a map on my bike. Not gonna do anything else to the engine, just exhaust and air filter. Dont really need to be able to change the tune all the time.
Old 06-03-2013, 05:39 PM
parrishbjj's Avatar
parrishbjj
Decided to pony up some dollars and get the Power Vision. I think Im just gonna get that first and see if I can use a better stock map to help this problem. Then when I get some more money together, i can get the exhaust and air filter.
Old 06-03-2013, 06:01 PM
figaroa03's Avatar
figaroa03
figaroa03 is offline
I have a similiar sound on My 2013 Iron. Best way i can describe it would be to say it sounds like a playing card in a bicycle wheel. If that makes sense. Mine is in for its 10o0 mile service so hopefully if anything is out of the ordinary they will find it. I have a DK air cleaner and Gronk mod. No popping or backfires at all. will probably remap or tune eventually though.
Old 06-03-2013, 06:29 PM
Sierra141's Avatar
Sierra141
Sierra141 is offline
No popping noise on mine either, I have vance hines short shots and an open vance intake with 5000 miles, mine was tuned at harley by the previous owner, thinking it might be the noisy valve train..
Old 06-03-2013, 06:42 PM
Mac10's Avatar
Mac10
Mac10 is offline
Not to change this subject too much. But how bout a whiz zing noise on the front rim. My spokes are tight and I have no problems with the ride but it gets louder or faster sounding as I go faster. Any ideas. Thanks
Old 06-04-2013, 12:06 AM
JustOneDean's Avatar
JustOneDean
JustOneDean is offline
My first thought was detonation, but I've been noticing the sound for about eight thousand miles whenever the throttle was wide open (which is fairly frequent). Wouldn't there have been noticeable engine damage by now if that was the problem?
Old 06-04-2013, 12:11 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
if it is actual detonation i don't think tank size would make much of a difference in hearing it. it is pretty obvious when it's happening. you may be describing something different then. if you have every had a car that spark plug knocked it is the same issue. does it sound like this? skip up to 12:00 mark in video.
Quick Reply: Engine Noise while riding
