Riding with choke out?
I was reading the recommended warm-up procedure in my service manual (89 XLH) and it said that I should let the bike idle with the choke out for 30 seconds or so, then to ride with it out for a mile or two. Does anyone do this? My bike will not go into gear with the choke out, I just get grinding. Is this a clutch adjustment issue? Thanks in advance.
I usually start with the choke fully out, let it run for about 10 seconds, then push it halfway in. I can then ride off, after a mile or so, I push the choke all the way in and I'm good to go.
That's what normally works for me, now if its been sitting for a while, or it's cold out, I warm it up longer without riding.
Bear in mind that when selecting first gear for the first time on each cold start, the clutch has not been disengaged since you last rode, so the plates can be reluctant to part company with each other. Be firm!
That's way too much time at full choke.
Aaron....Try pulling and releasing the clutch a couple times before trying to shift into first. Also, push the choke in a little to lower the rpm's. I've had some of the grinding issues in the past on cold starts & having the rpm's up.
How long you need to use full or partial choke, is relative to the ambient air temperature, but the shortest time possible is always best. Excessive choke use leads to fouled plugs.
Lots of good answers here already!
When first starting after a long time sitting, like overnight, it helps to work the clutch lever a few times before attempting to go into first. Cold oil viscosity will keep the clutch plates glued together making it more difficult to get into gear.
No doubt, as others have said, the high revs when cold don't help. When starting the engine cold I place the choke at the half way mark, twist the throttle to pump a couple of shots of gas into it right away before cranking. Once started push choke in as far as possible with the motor idling smoothly. Sometimes you need to give it a little throttle at first to keep it running too. Once you have set the choke back to the best, slowest idle leave the bike running for a minute, or two, or three. You will notice as the engine warms to operating speed the motor will speed up slightly. Adjust the choke down again until you are idling the smoothest and lowest rpm. At this point you may even shut down the choke completely depending on how it's running at the moment.
I often start up with half choke and move it to 1/4 choke, then to an 1/8 as it warms. Often when the choke is almost off completely I will ride (taking it real easy) and fully heat up the bike so it idles properly with the choke completely off.
Proper fluid levels in the transmission and primary make a big difference in being able to shift into gear. Check those levels.
Also as mentioned the clutch may need an adjustment. It's supposed to be checked every 5K miles. A precise adjustment may give you a lot smoother shift, especially when cold.
You may have a loose primary chain, or a faulty compensator that can give you issues with smooth shifting. Generally the chain, if too loose makes noise in the primary. And a compensator going bad typically gives a noise that many say sound like marbles rattling in a can.
Leaving the choke on full for an extended period of time (more than just a second or so to start it cold) will foul plugs. You should take out each plug and check what it looks like. Odds are good at this point you should just put in a fresh set.
