LED Headlight
Old 05-22-2013, 07:52 PM
Sierra141's Avatar
Sierra141
Sierra141 is offline
Default LED Headlight
Have a question for those of you that bought the daymaker headlight.
Once installed does the headlight seem to be loose in its bucket?
I thighned every bolt but it seems it shakes too much, I was thinking thats what the designers meant to do since the sportys shake and thats one way to avoid viration of the internals. Can anyone chime in..
Old 05-22-2013, 08:25 PM
elfnyc's Avatar
elfnyc
elfnyc is offline
my led is in tight as hell - no shaken at all -
ya sure you lined it up correct ?
Old 05-22-2013, 08:30 PM
BMM48's Avatar
BMM48
BMM48 is offline
Yep mine does not move at all...
Old 05-22-2013, 09:09 PM
xxINKxx's Avatar
xxINKxx
xxINKxx is offline
I don't have a 48, but is that headlight bracket aftermarket? I'm using the stock (black version) headlight trim ring and its only held on by a tinnnny lil screw and its solid. No vibration whatsoever
Old 05-22-2013, 09:48 PM
smoOve's Avatar
smoOve
smoOve is offline
mines has no Vibration at all either. its tight in the bucket and sits perfectly. you probably dont have it lined up right
Old 05-22-2013, 10:28 PM
DOMAPOI's Avatar
DOMAPOI
DOMAPOI is offline
Did you transfer over the rubber gasket from the old light to the new one? That is what makes it fit tight in the housing. Items #1 in each picture.
Old 05-22-2013, 11:10 PM
Sierra141's Avatar
Sierra141
Well I bought the bucket kit for it, it has a top rubber isolator and a bottom one, it was moving quite a bit so what I did is I put double sided tape on the bottom sandwiched beween the rubber isolator and the bucket itself and it tightnen up everything real good.
Thanks guys for your help....
Old 05-23-2013, 12:16 AM
mos68x's Avatar
mos68x
mos68x is offline
I just bought mine yesterday and installed and aligned it tonight, I had no vibration issues either. The kit came with the rubber ring which I used. Hardest trouble I had was trying to figure out how to align it. Had to download a manual to figure it out.
I think the $400 price tag is a little steep, but the light output is great. I might still get a couple auxiliary lights though, mainly for other people seeing me.
Old 05-23-2013, 06:27 AM
Sierra141's Avatar
Sierra141
I agree little steep but well worth it, no buyers remorse..
Old 05-23-2013, 06:30 AM
Sierra141's Avatar
Sierra141
Here is the final, the turn signals go great with the headlight..
Quick Reply: LED Headlight
