sportster camshafts
sportster camshafts
Hallo. Ive a little problem. I want to buy used camshafts to my sporty 1987.
I have one auction on Ebay but I dont know if It fit to my sportster.
I have 2 pics only and I see SIGN - 344.
My old shafts are signed - 1T,2T,3T,4T.
Here 344
Anybody knows - what MANUFACTURER and MODEL IT is?
Here 344
Pull the top cover, look for evidence of contact (dings or shiny spots). If you find some, file away a SMALL!!! amount of material to provide the necessary relief.
Please explain more what you are describing when you say the rocker boxes are disassembled and you still hear the noise - are the rockers off the engine, or did you just take the top cover and middle spacer off?
If you're still hearing it, use a long screwdriver like a stethoscope and see if you can't pinpoint the source of your noise. Remember that camchest noise will travel up the pushrod tubes just like a bullhorn!
"valve knocking"? Do you mean coil bind where the valvesprings are fully compressed before you get max lift outta the cam? If so - yes, that's a possibility w/the .536 cams.
