Strange Thing
Strange Thing
I went out to take the iron over to town to grab some things at the supermarket. it has been cold here (in the 30's at night) and upon trying to start her she couched a couple of times before she fired up, which has happened often when she has sat for awhile. ran fine to the store 6 or 7 miles away. in the store for less than 5 minutes. when i started up at the store it almost sounded like something grinding and thought it was the starter. made a couple more stops on the way and had the same sound. upon getting close and starting it at home it sounds like a cough from the air cleaner. strange sound. started three times in a row in the garage and it did it the first time but not the other 2. runs just like normal when going down the road or idling after start. just that small cough on start. any ideas? Might just be some type of vapor lock?
edit: also had it hooked to a harley battery tender for the first time before i started it today but can't see that would have anything to do with this. It is just the only thing i have done differently.
My Glide is doing the same thing! My starter is ancient, so I have bought a new one, however it is worth you considering getting a replacement starter clutch. Use Search, as the factory one is expensive, yet they are available much cheaper as aftermarket and there are bound to be pointers to suitable sources. I seem to recall Toyota use the same starter on some cars.
