Cycle Shack Mufflers - Iron
Yes it marries itself to one ECM only. While using Autotune, you don't have to mount it to your bars but it does have to be plugged in. Just put it in your pocket or something. After you flash the ECM, you no longer need the LCD module. You can keep it mounted as a gauge if you feel you'll use it. It monitors a few things like RMP, head temp, AFR and a few others I assume. As Aaron at Hammer Performance put it, "It's a very smart little bugger."
-Beer
-Beer
