Oil change
Old 05-13-2013, 08:59 PM
Hair53's Avatar
Hair53
Hair53 is offline
Default Oil change
Every 2500 Miles using conventional oil, does that sound right?
Old 05-13-2013, 09:08 PM
heritageblue2013's Avatar
heritageblue2013
heritageblue2013 is offline
Your asking for a bunch of different opinions. Follow your owners manual. If it says 5,000 miles for say engine oil, then 5,000 miles change it or sooner. I for example am on my second Harley. The manual calls for 5,000 miles engine oil changes. Longer on transmission and primary. I'll change all three at or before 5,000 miles using Mobile 1 V-twin 20W - 50 oil in all three boxes. Now if I only ride say 3,500 miles this year before winter, Ill change all three boxes in the spring before I ride again. Some will say to change it before storage.
Using conventional oil and changing at 2,500 miles sure won't hurt and will ensure your oil is doing it's job to the fullest. Oil's job is to lubricate and to contain dirt, gas, crud and hang on to these bad things till you drain it. Some oils additive packages can do a better job than others. Do a lot of research for yourself and come up with an oil that will suit your needs. Are you a high speed rider, stop and go rider, cruiser, etc. I hope this helps.
heritageblue2013
Old 05-13-2013, 09:09 PM
oppirs's Avatar
oppirs
oppirs is offline
leave it till 4k. OK?
Old 05-13-2013, 09:22 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
Overkill. Stick to the manual. If you use synthetic, it can even be extended beyond that.
Old 05-13-2013, 09:32 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,250 Likes on 1,641 Posts
Didn't your new Sporty come with an "Owner's Manual?" Suggest you read through it...especially the section on maintenance...JMO.
Old 05-13-2013, 09:43 PM
John Harper's Avatar
John Harper
John Harper is online now
Received 1,975 Likes on 1,346 Posts
Oil mileage depends on your driving environment, and how you drive your bike. Dust, dirt, heat, humidity, cold, etc. Hotrod, stop/go, or cruise, etc.
Maybe tell us where you live and how you ride, and then some in your area can give some more specific ideas.
John
Old 05-14-2013, 02:17 AM
emphacia's Avatar
emphacia
emphacia is offline
Every 3k here, I use dino not synthetic.
Old 05-14-2013, 05:55 AM
cHarley's Avatar
cHarley
cHarley is offline
I think the only place I've seen, every 2500 miles, is at some Harley dealers that are trying to keep their service departments busy and their customers wallets lighter. If your dealer told you 2500 miles, then you already know he's out to screw you.
Old 05-14-2013, 06:07 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Red face
No! It sounds like you're guessing. Read your owners manual, it is all laid out in there. If you plan on doing your own servicing the factory service manual is a great idea.
Quick Reply: Oil change
