Help me think! wifes bike starting issues and stuff
Old 05-09-2013, 03:37 PM
killphil's Avatar
killphil
killphil is offline
6th Gear
Default Help me think! wifes bike starting issues and stuff
Hey all,to start I work out of country half the year so am not always there am not a mechanical guru but can generally work my way through things. Last year my wife saved up all her pennies and bought a 88, 1200 it was recently all rebuilt and new custom paint fairing on it nice bike. She rode it for a month then the fun started first was an alternator gone,fine its older, then she took it back to harley as was a new leak and the wanted to straighten that out,she got half way there stopped for fuel and blam-o not starting got it in to shop and and was informed the starter was gone so she had that replaced, they still had troubles after that with wiring after they thought it was all good, they sent her home bike running ok. This spring the bike was not cranking charged battery and went through wiring ( was a mess got all cleaned up, relay was good and got her cranking again but we were waiting for calliper parts so couldn't drive her, there were buyers coming to check out ( she had enough fun and scared to take it anywheres) so we were checking it out and starting up regularly, the other day she went to take her for a run warmed up bike for 5-10min drove half a block the bike backed fired stalled and then would not crank again, I'm at work, my wifes head is doing the exorcist and she's fuming any ideas as what we can check out next????
Attached Thumbnails Help me think! wifes bike starting issues and stuff-2216ge6_20.jpg
Old 05-09-2013, 05:12 PM
subguy's Avatar
subguy
subguy is offline
I didn't see mentioned that she had a trickle charger connected to the battery when not being ridden. I mention this as you are probably aware that starting the bike for short periods will not charge the battery sufficiently. Eventually there will not be enough charge to turnover the bike. It may be a contributing factor to what she is experiencing. I hook up a charger whenever I get back home and through the winter. I still have the original 2007 battery in my bike due to this.
Old 05-10-2013, 01:22 AM
jojoenglish85's Avatar
jojoenglish85
jojoenglish85 is offline
please use the search function.
Old 05-10-2013, 06:44 AM
mrfikser's Avatar
mrfikser
mrfikser is offline
it there any chance that it is out of fuel??
Old 05-10-2013, 07:00 AM
killphil's Avatar
killphil
killphil is offline
6th Gear
yeah trickle charger has been on, fuel is good also.
Old 05-10-2013, 07:07 AM
killphil's Avatar
killphil
killphil is offline
6th Gear
I have been checking out forums and gave me some ideas plus reading through manual. Been doing so for a couple weeks was working ok but I was waiting for a caliper rebuild kit before takeing her for a run....should have just gone apparently it stopped quite well when she stalled out haha
Old 05-10-2013, 09:14 AM
mtnbikeadam's Avatar
mtnbikeadam
mtnbikeadam is offline
to me it sounds like its time to buy a multi meter and start checking wiring, bad grounds, and pinched wires is what i would check for.
Old 05-10-2013, 09:20 AM
gwaligorski's Avatar
gwaligorski
gwaligorski is offline
I would also pull the battery and lightly sand down the contacts on the ground and Positive. I thought I had a bad starter for months even bought a new one when it turned out to just be slightly tarnished connections.
Old 05-10-2013, 11:19 AM
lo-rider's Avatar
lo-rider
lo-rider is offline
Take it to a pro.
Old 05-10-2013, 02:21 PM
killphil's Avatar
killphil
killphil is offline
6th Gear
Thanks did that cleaned up some connections reterminated a couple there was a huge mess under the seat someone was trying to reuse old multi connector and splicing in additional wires and **** cut out all that and reconnected wires
Quick Reply: Help me think! wifes bike starting issues and stuff
