no-start troubleshooting
...now thats a new option for me. I havent changed the battery in my FOB.
additionally for the previous recommendations:
i will try disconnecting/reconnecting the battery today (I previously only checked the connections to make sure I didnt have a lose connection - they were not loose).
Also, I cannot exactly say that my battery has a "full charge", however the battery charger that I bought from my local Harley shop has an LED light indicator that started out showing red. After about 45 minutes of charging, the LED light turned to green, so i presume that is telling me the battery has a full charge.
Also if you want to try something different. You can leave your negative connected to the battery while its in your bike, then connect your charger to the positive lead and hook the negative up to any part of your frame. Then after about 6 hours while the charger is still hooked up try starting the bike then. If it sounds weak then you need to leave it alone for another 6 hours or so. This way works best for me now, because its a pain in the rear-end to keep taking the battery in and out.
I know this is something I am sure you have checked and I don't want to come off sounding like I am calling you and idiot, but, have you checked your "run/off" switch on your right handlebar controls? I know of so many new users that have had this problem only to find out they forgot to turn the switch back to the "run" position.
Jor3lBR
08-19-2008 10:40 AM
