anyone ever experience some weird noises when walking in reverse to park? I am experiencing that with my sportster and it doesn't sound too good. Its like a loud noise that I can't really describe.
Sorry, my description isn't really helping I will try to post a video later.
Just wanted to know if anyone had wierd noises while reversing.
Well, if you're moving the bike backwards then the clutch is in or it's in neutral, so the only thing I can think of right now is something with your brakes.
Can you at least determine where the sound is coming from?
Watch the belt teeth for rubbing on your wheels pulley. It's probably the belt teeth rubbing on the edge of that pulley. You can lift the rear wheel off the ground and rotate the wheel backwards to see if that's what's happening.
